I was wondering if any others have had problems with the spinner to cowl clearance? The cowling was trimmed to the scribe line and fitted as per the instructions. Now that the spinner is on, the top cowl will interfere with the back of the spinner and backing plate. It appears that more f/g will have to be trimmed at the top where it meets the upper fuse. Hinges will have to be relocated, etc. How much clearance is typical between the spinner and the cowling? It appears that approx. 3/8 inch will have to be trimmed. Any thoughts? Thanks in advance for all of your help.
