dick seiders
I worried a bit about fitting the cowl several months ago, and the prop spinner later. You would never do that on an earlier RV kit. Now am at fitting the cooling duct and discovered at assembly the lower cowl has 3/32 to 1/8 clearance which is OK, but the upper is at 1/64. I would appreciate any comments from those of you who had this experience and your fix. Thanks.
Dick Seiders
Dick Seiders
