I made an offer on the prop for sale but need just one piece of wisdom from our mechanic types.The sensenich prop spacer number in the model number is S9. My prop has a spacer code of S16. Am I correct in assuming the spacers that are behind my current prop will be used with the new prop and that the spacer code is given so you can get the correct length prop bolts?
JimS
JimS
