Viewed from the front, most people set things up so the prop stops (i.e. begins the compression stroke) at about 10 O'Clock/4 O'Clock. This makes for a good starting point if you need to hand prop.
If you base things on TDC, you're probably looking at 9:00/3:00 or possibly 8:00/2:00.
