I recently acquired a three blade ground adjustable prop that has no markings on it as to who made it. The only marks are on the inside as to insure that the prop gets reassembled with the blades in the same socket. The last 1/3 rd of each blade is covered with glass and the overall construction is beautiful. I have done some research and have reason to believe it is a Bernie or Maggie Warnke prop.
I have several questions about the prop.
1. Does anyone have any information that they can share?
2. With regards to the band clamps. How tight should the 3/8 bolts on the band clamps be torqued?
https://imagizer.imageshack.us/v2/677x508q90/812/3m6z.jpg
https://imagizer.imageshack.us/v2/677x508q90/706/1cif.jpg
https://imagizer.imageshack.us/v2/381x508q90/855/kkq9.jpg
Russ
RV9-A N1909K
Russ
RV9-A N1909K
