Prop Ground Clearance with Catto and -9A
FlyingArcher
Hello,
I'm filling forms for the authorities to declare beginning of my -9A construction, and they are asking for a lot of technical info. I've found almost everything they ask, except for the propeller ground clearance.
As I plan to install a 66" diameter, 3-blade Catto prop, would someone using this on their -9A be kind enough to measure this ground clearance?
Thanks in advance
Thank you
Thank you Dave,
That's just what I needed, and as usual this site proves to be the best live reference manual on RVs. :)
Cheers
