DCalland
Member
I have a Lycoming O 360 and have the prop governor that shipped with the Van's FWF kit. The only way the Jihostrol governor fits the pad on the engine such that the control cable has to route to the bottom of the governor and it appears that it should be to the top (the arm is on the bottom). My friend flies a 7-A also and the arm on the governor is 180 degrees or on the top side. The governor design is also different as far as the case but the mount looks the same from the outside. Anyone else having the same problem or have an opinion?
