Bill.Peyton
I just installed the all of the quadrant cables and have a question. For the Throttle and Mixture cable, I get full travel on the quadrant which corresponds to full travel on the fuel servo. With the prop governor, I only see about half travel on the quadrant for full travel on the Hartzell governor. The only way I can see to change this is to replace the Hartzell actuator arm with a longer length. I really don't want to mod the quadrant arm shorter as the force is already right at the acceptable range.
Both the engine and prop/gov. were purchased through Vans
