Any ideas on this one? It does not allow me to gradually feed in control. It's all or nothing. The 3 blade Hartzell prop goes from the base fine pitch to full coarse once the governor starts kicking in. It's an older model Woodward governor. We've dialed in and out the adjustment screw with no help. We've been through it without seeing anything obviously wrong. Has anyone experienced this same problem, and if so, what did you do about it? Is it worth sending off and refurbishing? I'm at the end of my rope and I'm fixin' to order a new one. Which prop governor is recommended? I'm thinking about the PCU 5000X. Ouch!![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
