prop clocking
scottw
Member
I haven't gotten a definitive answer on this so I thought I would throw it out there, I have a MT constant speed prop on a 0320 that can be mounted in any position, so which position should it be mounted? 10/4 for hand propping or the clocking that gives the least vibration or ?
10 and 4 is the default clocking, but if you get a smoother operation with a different clocking, then that should be used.
