Hi Walt-I'll be bringing my balancing equipment to LOE, maybe you should stop by
Hi Walt-
I know you have a great reputation for prop balancing. For those of us who can't make it to you, do you have any suggestions about what questions we should ask of other prop balancers in order to be most likely to get the best results (e.g. what types of equipment or process we should inquire about)? I'm right now getting my prop repitched by Craig Catto and balancing is one of the first items on my list once I get it back.
Thanks.
I would ask things like:
What type of equipment do you use? (MicroVib, ACES, Chadwick are the best)
What vibration level do you typically get after balance? (I guarantee .05 IPS or less)
Where do you place the weights? (on RV's with Lycs the normal spot is the flywheel so you don't have to drill any holes)
Do you do a spectrum analysis?
What type of documentation is provided?
Is the work done by a certified mechanic?
Walt, what would be a fair price for it when done well by a qualified person?
