Who in the Portland area does prop balance? Ed RV8 TMK
N402RH Well Known Member Dec 6, 2009 #2 If you are a EAA 105 member you can use our prop balancer. Rob Hickman N402RH RV-10
Russ McCutcheon Well Known Member Dec 6, 2009 #3 Person Field Greg at Pearson field owns the equipment and does this on his own, he is the avionics man at Aero Maintenance on Person Field.
