Think I boofooed another part
Cut a flat on the -8 prop bolt washers, and as I was tightening them, a couple turned and cut 2 fairly deep smilies in the spinner plate..I polished it out, but the metal has an indentation now..Should I replace this part, or would adding a little aluminum braze be ok? Also, the -7 washers are only slightly smaller, but the bolt hole is too small for a 360 prop bolt. Any problem with machining the hole to proper size to accept the bolts..or should I continue with the flat on the 2 inch washers?..Any thoughts appreciated..(sorry for the "wall of text")....
