Right 'duffers' guide or how I operate!
Oil: Personal choice is Shell Sport Plus 4. In reality any oil on the Rotax list is OK or at a pinch a high grade 4 stroke motorcycle oils that lubricates both engine and gearbox.
Coolant: Personal choice is G48 type antifreeze concentrate mixed 50:50 with distilled water. Avoid tap water!
Bleed the air from the coolant system to give near full just beneath the pressure cap on top of the engine. Don't forget to fill the plastic expansion bottle to the indicated marks. (For the first couple of flights the coolant will drop a bit as the air escapes from the small cavities around the engine and the water gives up its air). Top up as neccessary.
Purge the oil system as the Rotax SI. I cannot stress how important this is!!!!
ANY time you open up the oil system (not just topping up the tank) for example disturbing any oil line pipe connections, changing the oil filter or inspecting the magnetic plug etc. I would suggest you go through this procedure.
Add about 4 gallons of fuel to the tank. I would suggest 100LL Avgas as it might be in there a while before you go flying.
Chock the aircraft, deep breath then start as the POH. You should see oil pressure after 10 seconds, if not shut down immediatly and purge again! Don't forget to test the lifters again.
Let the engine idle at 1800-2000 RPM for 10-15 minutes whilst you keep an eye on all the engine guages and listen to the engine.
Couple of top tips:
ULS: Start the engine on the choke with the throttle fully closed,( There is a reason for this but it'll take a long time to type) as the engine springs to life and the oil pressure rises reduce the choke slowly and increase the throttle to give you the 1800-2000 idle.
iS: Set the throttle to 33%, This is shown on both the Garmin and Dynon displays, it doesn't mean moving the throttle 1/3 of the way forward! Avoid the POH figure of 50% as this is a lot of power on a cold new engine! This should give you about 2000 RPM once started. Watch the oil pressure, again 10 seconds for it to rise.
Both engines:
When you are going to shut down let the engine idle for a while then as you close the throttle turn the key off. This will stop the clunking as the engine shuts down. If you want to know what clunking is, close the throttle wait 2 seconds then turn the engine off.
Have a bit of faith, Rotax run every engine for 60 mins in the factory prior to shipping so in real terms they are almost ready to go.
I've attached a couple of things that may help.
Good luck,
John.
PS If you want any other info just post.
https://www.youtube.com/watch?v=UwARvpIP9-k
