avengingangel
Today I removed my 200, inserted the 210 unit and nothing, no power. Am I correct in assuming it should be direct replacement? The pins in the back should be the same as the 200? With a little bit of moving it seemed to slide in and connect. The 210 unit seemed to sit out a little but where probably talking millimeters, had to be plugged in enough for a connection. Should have powered up I would have thought. Ideas?
