Dgamble
I was a little embarrassed when I went to have my two year transponder check on my version 12 + ADSB Skyview. I couldn't get it to go into ALT mode! I knew that ALT mode was working because I had seen it in flight on the way to the avionics shop, but it was steadfastly clinging to GND mode now that I was, well, on the GND.
I also remembered that it has been staying in ALT mode even while on the GND since one of the more recent firmware upgrades, which I just assumed was deliberate on the part of Dynon in response to this:
"This SAFO advises all operators and pilots of the need to ensure that transponders are in the
altitude reporting mode whenever their aircraft is on an airport movement area at all airports."
http://www.faa.gov/other_visit/avia...afety/safo/all_safos/media/2015/SAFO15006.pdf
The most recent change to anything related to the avionics was the installation of the ADSB kit that I bought from Van's. As part of the installation, I used the Van's supplied config file. This is what caused the highly irritating alarm when it decided that my canopy wasn't properly latched due to the lack of the canopy latch safety switch. It seems that the config file also reverted back to AUTO ALT/GND mode for the transponder.
If you find yourself in this position, just go to the transponder setup page, select AUTO ALT/GND, and set it to NONE.
