K&N air filters that I've purchased recently have tended to run 1-2mm "short" (62-63mm v the 64mm spec), which potentially comprises the seal between the top of the air filter and the plate on the bottom of the throttle body (IO-540). My plan is to fabricate and install an aluminum plate on the bottom of the FAB; it will have a hole in it to allow any leak-down fuel to escape via the existing FAB vent line. This seems to be a relatively common fix for FAB abrasion, and should also solve my issue by raising the filter by a couple of millimeters. Pro-Seal seems to be the adhesive/sealant that I see others have used.
Questions:
1) Is pro-seal indeed the best adhesive to use for securing the plate to the bottom of the FAB? Given that no one seems to enjoy working with Pro-Seal, is there another reasonable alternative? This is about simply securing a piece of aluminum with an adhesive that will stand up to fuel--not something as critical as sealing fuel tanks.
2) Surfaces obviously need to be clean. Thoughts on acceptable solvents to clean/de-grease the fiberglass portion of the FAB?
3) A friend passed some pro-seal to me should no alternatives emerge from Q1 above. I've been keeping it in the hangar fridge. The other day, I noticed that a couple of soft drink cans were empty. Others were OK, but presumably the fridge temp dipped below freezing at some point. Does that render the Pro-Seal unusable? If yes, I have all the more reason to consider an alternative.
Thanks in advance.
Questions:
Thanks in advance.
