Happy Tanksgiving!!
Woo Hoo!
Both tanks passed the manometer test this past weekend (finished with a reading this AM).
What an ordeal! I did both tanks at the same time. The first proseal adventure was October 29, so you see it took about a month. It took two episodes (stiffeners, then caps and drains) before really gaining control of the goop with purchased syringes, tonge depressors, popsicle sticks, gloves, MEK and paper towels.
The syringes were easy to load with a tongue depressor since the depressor was about the same size as the syringe. Just scoop it and mash it into the syringe. My wife and I would load one or two syringes and do a couple of ribs a night. We were ready for the back baffles right before the holiday. My kids came home from school and we jumped into it on Friday. With 4 people, it was quick work to butter all the parts, assemble, cleco, rivet, pop rivet, clean up. I hold great regard for the builders that do this by themselves. There was a lot of man hrs into it.
On thing I did notice was that the "proseal" sold by Van's is desolved by MEK even after MANY days of cure (like 10), so it was very easy to get rid of slops and drips that were undesireable. And please don't assume it was mixed wrong because it was not. I used an accurate balance and came out almost perfect at the end of the can.
I am especially happy about the pressure tests because I did not install the access plates. I definitely had "shrinkage" though, per the venerable Seinfeld episode, before the pressure tests
![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
. I have capacitive gages that should not need maintenance and I felt that if I had some sort of construction leak, the access plate would be in the wrong bay anyway. I saved a bit of weight and have access rings to use in the back baffle if I have a problem later.
Trying to follow an old racing guideline " Worry about the ounces and the pounds will take care of themselves "
