I'm studying Z-11 schematic and it has a set up for on/off/prime and details Electric Prime Valve. Is this the correct set up for A/P Fuel Pump or does this relate to other fuel pumps?
This switch works for the fuel pumps Van's calls for on carb'ed engines. It is nice because it eliminates one extra switch in your panel. Hope this helps.
On an injected engine you just turn on the electric fuel pump for a few seconds with the throttle open and mixture rich and it sends fuel through the lines to each cylinder intake port.
