that's a routing I hadn't thought of, over the top, I was trying to route along the sides and along the sump, but over the top might be easier and neater!!
What are you using for a primer valve next to the gascolator?
Ron
Ron
I liked the fact that there is only one baffle penetration!
Err... that's because the upper primer port holes are being used...
If you use the lower ones (per the Lycoming figure), then there are no baffle penetrations.... at least for carb. engines....
Primer port location at bottom left of the cylinders is shown on this Tiger O-360 (not mine......), same baffle arrangement on the cylinders as our RVs...
gil A
Gil, is the idea to shape the lines along the intake tubes, clamp to same, then tie to the sump and route back to the primer....
Ron
