I also read all the posts about weld-on & over glassing and decided I didn't want to deal with the lump or all the fix up if I had to replace a window. I figured the cracking wouldn't be too bad, just like fillets on most big planes. They usually crack too. So, I followed the plans exactly. Then I painted and all the joints were perfect and invisible. Four months later the cracking started. Last Friday at about zero degrees I took my roadie Jake for a ride. 20 minutes in the cold & I felt a draft. We looked all over, checked vents etc. and couldn't find it. I landed and discovered the right door window popped loose with the lower front corner scooping air. Grrrr!. I took the door to my hangar, routed the joint with a dremel and started carefully prying. I almost got it out without cracking, and this is what I found. The stupid weld-on was adhered to the acrylic, but popped off the fiberglass almost clean. The bond sucked big time. The weld-on was going brittle and if you crushed a piece it went powdery. I've ranted in the past about Vans glass attachment methods, so I won't do it again right now. These cracks aren't just cosmetic. I'm getting the nasty feeling that when you see cracks they are an indication of debonding all throught the joint. I'm also afraid that over-glassing may just hide the problem and that the debonding is happening underneath anyway. I fear the differing expansion rates between acrylic and fiberglass are just too much for the rigid weld-on joint. So, instead of sitting here pointlessly posting I started doing homework on weld-on and every other glue/adhesive I could think of. Now that I've done that, I can't fathom why Vans chose weld-on in the first place. The whole theory is just wrong. So, I've got the new window fitted and I'm waiting for some 3M 5200 to show up. It's white, has 3 times the tensile of Sika, 900% elongation and is supposed to be compatible. I'll try it on scrap and if it looks good I'll rout a fillet bevel in the joint and glue that sucker in there. Wish me luck.
I'd recommend that all you 10 guys do a little "push testing" on your glass and if anyone else had or has a window coming loose, I'd like to hear about it.
