Only one problem, solder connections vibrate and crack. That's why it is best to use a crimp on connectors and push those on your starter button. Or, in my case, a ring terminal, and screw it to the starter button.
PS. Use an aviation crimper that does a double crimp. Then you can put shrink tubing over it.
