Richard Connell
I can’t get my head around what should be an easy question…
I have a MH bottle which uses a 4-20mA sender to drive the pressure gauge on the panel. So far so good.
I know I could also put a resistor in parallel to ground at the GEA to convert this to a voltage to read the tank pressure using one of my spare GP inputs. I want to do this because I like data and this way I’ll be able to track usage. Also it’s easy.
My question is can I do both at the same time? So two gauges in series off the same current loop sender. One current based and one current but converted to voltage at the receiver - or is this going to lead to two incorrect readings?
Thanks!
Thanks!
