Smilin' Jack
We just had our Challenger Aircraft painted in Sanford, FL at Starport aviation and I was extremely interested on how professional shops etch and alodine the aircraft or paint a new aircraft.
The head of the paint shop Kerry told me that that etching and alodining an aircraft is ancient history and that I need to get my thinking up to date. He said use PreKote. I have bought this and read over the advertising and this is what the military is using on their paint jobs now. so how do you use this stuff.
Spray PREKOTE on and use a scotch brite medium pad and wash your aluminum pieces with it. let it stand 2 minutes then spray more PREKOTE on the piece and again wash it. After all this just rinse it with water from a hose...
I have done my tail surfaces and primed my horizontal vertical and all the elevator and rudder and the results are great.
here is the blip for Aircraft Spruce on it.
Give it a try I did and I am pleased.
Smilin' Jack
PREKOTE? SURFACE PRETREATMENT
PreKote? a simple procedure that replaces the use of traditional chromate conversion coatings and the need for acide etches, solvent washes and other toxic processes. Small aircraft shops have also used PreKote? to successfully replace the use of chromate conversion coating pens for smaller repair areas. By eliminating the need for these additional processes, paint preparation time and cost can be reduced by up to 40%.
Approved for use by the Boeing Commercial Aerospace Group, Department of Defense and currently flying over 1,500 United States Air Force aircraft, PreKote? has proven consistent results with a variety of paints and primers. PreKote? can be used on a wide range of surfaces including aluminum, steel, magnesium, titanium, CRES, galvanized, composite and plastic surfaces.
Environmental, Health & Safety Reason for Using PreKote
The use of PreKote? does not trigger categorical industrial user status under the Environmental Protection Agency's metal Finishing effluent guidelines. This makes PreKote? easy to dispose.
PreKote? use also eliminates the need for forced air containment suits which are required by OSHA when using traditional chromate conversion coatings. Simply rain gear and goggles/face shield are all that is required.
Select Size: Quart Gallon 5 Gallon 55 Gallon
Smilin' Jack
