blincaviation
Member
While I am nowhere near needing a pre cover inspection, I do have a question regarding the point of construction when you book it? I know the title is the answer itself i.e. "pre cover", is there an expectation from the inspector that, lets say a HS Skin is attached on the bottom only or to leave it off completely? I assume, maybe wrongly that if they are inspecting your riveting skills then the more rivets to look at the better
Or of course I could be completely out to lunch with my assumptions....its been known!
With the above in mind, is there a ball park on how long it takes to get appointments or is it too variable to judge?
