Pre buy Needed North San Diego Ca
Pre-Buy recommendation
I can highly recommend "AeromechaniX", located at Ramona, CA. KRNM. A very good maintenance shop.
Francisco Jimenez is the guy to call: 760-522-8320.
francisco (at) aeromechanix (dot) com.
Straight-shooter, very knowledgeable, and has a lot of experience with Van's RV aircraft.
Hi Derek! I did fly my T-6 into Fallbrook a couple of times, plenty long enough.
But I don't consider myself qualified to do a pre-buy on an RV-8. Maybe Francisco would fly over in his Cessna 150 and look at it. The OP should call and check.
Stay warm!!
Just start at the tail, HS forward spar mounting to fuse, hole edge clearance......O.....that's another thread, sorry. :D
John Shablow is a DAR located in Temecula, Ca. He does many RV's in California and may fly his RV in to do inspection. Trouble is I just moved and can't find his number. I'm sure there is a fee but ---------------
