David-aviator
I am reading the pre-build manual, word by word, to see if taking on this project makes any sense for me.
As Scott Risen commented at Van's, if you've built one of our later models, the RV-3 will be a challenge. Ken Scott discouraged the whole idea, his conclusion was it is a terrific opportunity to screw up a build.
All that being said, I am open to doing it. It certainly is not rocket science, so to speak. I've built the H frame before when doing the first tail section for the 7, it was actually a 6 build. Later it became the matched drilled item it is today.
On page 6-2, the very first pieces to fabricate are the HS-303 channel and the HS-307 reinforcing strips. The written word seems to indicate the channels are pre-formed, the drawing at DG-14 says to remove certain flange corners "after bending." Are the HS-303's fabricated from flat .32 sheet or from pre-bent channels?
Also, there seems to be no clear drawing of the HS-307's, just a simple short segment of how they look, no dimensions whatever.
I will read on and perhaps see a more detailed illustration of the HS-307's.
