I am fitting a Plane-Power AL E160/V to my 0-320 E2D. It already has a Sky-Tec 122-NL starter fitted. The strap that connects the main AN7-42A mounting bolt of the alternator with the body of the starter is 1/16” too long between hole centres. I believe the extra strength of this strap is critical in dealing with an engine kick-back, so I want to get it right. I can see only one way of mounting each of the accessories And the lug on the starter is part of its body casing. so I suspect I have a dud Plane Power part. Either the V-1002 strap or the V-1003 bracket is bad.
Has anyone else come across this problem and how was it resolved?
