Start by saying that I have a non-conventional engine/prop combination.
Being new to the constant speed prop I am a little at a loss as to what the ideal operating numbers are for econ and 'regular' cruise.
Background - Note: these are a bit different from the stock Vans:
1. For climb I have been applying full throttle and RPM settings, leaning as I climb. I get to 8500 fast enough and have no temperature issues. Sound good so far?
2. For cruise at height I reduce RPM to 2375-2400 and restrict throttle a little. I don't know just how much since I don't get any feedback on power percents. My flight averaged fuel burn is pretty reliably 12gph based on a mixture of 1-4 hour flights. I don't have a fuel flow meter installed (yet). Does this sound like a good cruise setting? Again, no temperature issues.
3. For descent I reduce the throttle and RPM to roughly 2300/23" though I often see higher EGTs then on some cylinders. CHTs are always even and close 160-180F. Is this expected?
4. Leaning - I used to fly a Warrior and leaning was easy even with one set of sensors, you'd lean until it got rough and then back off a little to an ideal setting. Given I am carbureted but have a CS prop, what is the procedure, and is it even possible to get LOP behavior for greater fuel efficiency?
Curious if there are any other operators out there with similar settings and thoughts to share.
- O-540-B4A5 235HP carb. engine, 2575 max rpm
- Low compression Superior cylinders
- Hartzell HC-C2YR Prop with F8468R3 blades (81") and Hartzell gov.
