Piper J3
This is interesting…. I asked ChatGPT to estimate % power at two different cruise settings normally used on RV-12...
Estimate % power for 5000 RPM - Vans Aircraft RV-12 with Rotax 912ULS engine, 3-blade E-prop optimized for cruise, 73F and 2800' Density Altitude while flying at 2000 MSL. Running 93E10 Mogas and burning 4.5 GPH
Given your specific conditions, we can make a fairly good estimate using both the Rotax 912 ULS brake-specific fuel consumption (BSFC) and typical RV-12 performance.
Conditions
The Rotax 912 ULS typically has a BSFC of about 0.42–0.45 lb/hp/hr in cruise.
Fuel weight:
At BSFC = 0.43:
Percent Power
The 912 ULS is rated at 100 hp at sea level.
That gives:
Relative to the available power at that altitude:
For a cruise-pitched E-Prop on an RV-12:
Best estimate
5000 RPM under your conditions corresponds to approximately:
If you also know your true airspeed at 5000 RPM (or your GPS groundspeed on a calm day), I can refine the estimate further by correlating power, propeller efficiency, and aircraft drag for your specific E-Prop.
Estimate % power for 5500 RPM - Vans Aircraft RV-12 with Rotax 912ULS engine, 3-blade E-prop optimized for cruise, 73F and 2800' Density Altitude while flying at 2000 MSL. Running 93E10 Mogas and burning 5.0 GPH
Given your configuration, we can make a fairly good estimate.
Conditions
The Rotax 912 ULS has a Brake Specific Fuel Consumption (BSFC) near 0.42–0.45 lb/hp/hr at cruise.
Using 5.0 GPH:
Relative to the 100 HP engine:
A cruise-pitched E-Prop on an RV-12 typically produces:
Estimated power
≈70% power (±2%)
A reasonable estimate is:
5500 RPM = approximately 70% power
Interesting observation
A stock RV-12 with the Sensenich prop often burns around 4.7–4.9 GPH at this power. Your 5.0 GPH is consistent with:
If you also tell me your true airspeed (or GPS groundspeed in calm air) at this setting, I can estimate your propeller efficiency and determine whether your E-Prop is pitched slightly coarse, about ideal, or slightly fine.
Conditions
- Aircraft: Van's RV-12
- Engine: Rotax 912 ULS (100 hp)
- Propeller: 3-blade E-Prop, cruise optimized
- RPM: 5000
- OAT: 73°F (23°C)
- Density Altitude: 2,800 ft
- Pressure Altitude: 2,000 ft MSL
- Fuel: 93 E10 mogas
- Fuel Flow: 4.5 GPH
Fuel weight:
- 4.5 gal/hr × 6.0 lb/gal ≈ 27 lb/hr
At BSFC = 0.43:
- 27 ÷ 0.43 ≈ 63 hp
- 27 ÷ 0.45 ≈ 60 hp
Percent Power
That gives:
- 60–63% power
- 60–63 hp ÷ 91–92 hp ≈ 65–69% of available power
- 4800 RPM → ~55–58%
- 5000 RPM → ~60–65%
- 5200 RPM → ~68–72%
- 5400 RPM → ~75–80%
Best estimate
- 61–63% engine power (relative to the engine's 100 hp rating)
- 65–69% of the maximum power actually available at a 2,800 ft density altitude
Conditions
- Engine: Rotax 912 ULS (100 HP)
- Prop: 3-blade E-Prop pitched for cruise
- RPM: 5500
- OAT: 73°F
- Pressure Altitude: ~2,000 ft MSL
- Fuel: 93 E10 Mogas
- Fuel Flow: 5.0 GPH
Using 5.0 GPH:
- Gasoline weighs about 6.0 lb/gal
- Fuel burn = 30 lb/hr
- At BSFC = 0.42:
- 30 ÷ 0.42 = 71 HP
- At BSFC = 0.44:
- 30 ÷ 0.44 = 68 HP
- 68–71% power
- 5000 RPM → ~55–60%
- 5200 RPM → ~60–65%
- 5400 RPM → ~65–70%
- 5500 RPM → ~68–72%
- 5600 RPM → ~72–75%
Estimated power
≈70% power (±2%)
- an E-Prop pitched for cruise,
- slightly richer mixture at this operating point,
- or simply normal engine-to-engine variation.
