islandmonkey
I have found an apartment in Zurich with a large enough basement that offers the possibility of being able to build my 3 at home. The basement in this apartment has plenty of natural light through windows at around eye level. It also has a good location for the compressor so that the one and only neighbour will not even hear it. The only drawback is getting the fuselage out once built. I would be able to remove a floor to ceiling window to allow egress of the fuselage from the basement, if the fuselage was narrow enough to go through the window. Failing that the fuselage possibly could be manhandled up the straight staircase and out through a patio door.
Here is a link Zurich Apartment Click on Bilder to see pictures.
My questions are, what is the width of the fuselage at its widest point and the length of the fuselage without the engine mount attached. Also does anyone know the approximate weight of the fuselage without engine mount, instruments, canopy or undercarriage.
Thanks in advance.
Thanks in advance.
