Possible Trim Wire Length Issue-Finishing Kit
MartySantic
Anyone have an issue with the length of the trim wire harness? Mine is about 14 inches shorter than the cable with the 37 pin connector (the trim wires will plug into this connector). I left the prescribed length of the 37 pin connector cable above the panel shelf. After wrapping the wires over the pedals and installing the pedals I do not think the trim wire will be long enough.
I only have about 7" extending aft of the tailcone bulkhead. Should be just enough to wrap around the cable clamp attached to the servo tray.
I have printed all of the revisions and have been using them for Section 31 assembly. The trim wire seems to be 14-18" too short.
