Please could someone walk me throough this step? I've made the stops, got the ailerons in place and have just spent an hour fiddling, trying to get the stops into the right place, to no avail. I'm obviously doing something very silly.
Before anyone suggests it, no, I cannot use the delrin washer method, as the inspector will not approve it (I'm in the UK - much more restrictive).
Is there any way to measure and lay out the stop location on the aileron bracket with the aileron off? A big part of the problem is access. If I had a long enough, thin enough, clamp I'd be part of the way there..... I think.
One suggestion has been to rivet it roughly in place and then grind the stop to give the required range of movement - but I don't think I can get the stop in place accurately enough even for that approach.
Chris
Chris
