Finally got the canopy side and rear skirts all riveted together, like the fit, but now what? I'm looking at the pop rivets and wondering about filling them with glass or just painting over them and letting them show.
If you prime and paint, does a normal double coat of epoxy primer "sorta" fill some and not others and leave them all looking a little different or does a coat or two of high fill primer fill them up?
For those that used a real filler like bondo or fiberglass, did you just mix up a batch of epoxy and ballons and then fill and sand? Did that completely cover the rivets or leave the outlines showing?
I "think" I am going to fill with epoxy and balloons, and then put a single layer of light 2 oz bid over all of them and be done with it but wondered what the pros and cons were before I got too far. ( seems like a lotta work
Similar question on the cowl rivets,.. did you just 1) prime and paint 2) cover with epoxy when you filled the pinholes and then paint or 3) epoxy and then layer of light glass? Pros & Cons ???
Comments and pix appreciated?
Thanks Bill S
7a finishing
Thanks Bill S
7a finishing
