I just picked up a large sheet of steel (2' x 4' x 1/4") from the metal yard and would like to know the best/cheapest/easiest way to polish it for use as a back-riveting plate. Any ideas?
i did the 60 on a side grinder and then 80 on a DA sander. oiled as prescribed. mine is 1/2 by8x18 and a 4x4 angle bolted to the side of the table. which is made from 4 inch channel
Scotch bright and an orbital sander, as has already been mentioned, if the surface is any where near flat. I used the top of my Delta Unisaw to rivet part of my rudder on. Didn't harm the top of the saw at all and worked like a charm.
I used 80 grit and a belt sander to get mine down, but my piece was heavily scaled. My plate is 1/2" x 4" x 75" and is routed into the table. Worked great.
