Scott, Hey thx for the link. In one of the reply's you mention the Adjustable set holder and rivet set rod. I found the adjustable set holder (Avery) but couldn't come up with the rivet set rod. Also which length yokes do you find to be the best.
Thx,
I would highly recommend getting your squeezer from Avery. I've had mine for about two years now. I dropped it on the floor last week and it quit working. Bob Avery repaired the squeezer and had it shipped back in under a day. Bob straightened the brass tab, reamed the bore on the brass valve body, replaced the “o” ring in the brass valve body and checked it out. He did this at no charge. Considering this was also repaired as Bob was preparing to leave for Sun N Fun, I have nothing but compliments for their service]I also went through the standard learning curve a couple years ago. (i.e. how to squeeze -6 rivets) Bob spent some time on the phone giving some tips and tricks.
As far as yokes go, I have a 3", 4" no hole, and a longeron. I know there have been a couple threads debating on which ones work best. These have allowed me to squeeze about 99% of the squeezable rivets. I just use the rivet gun on the others. I've just been too cheap to buy like a 2" no hole to get those odd ball situations
If you get the squeezer and adjustable set from Avery, you'll have everything you'll need but the yolks and dies. I have the die set from Cleaveland Tools. I had an A&P tell me that he like the Cleaveland dies better than Avery's, however I can't substantiate that opinion. While Cleaveland's dies have worked well for me, I don't have any experience with the Avery dies
Both Avery and Cleaveland are great tool vendors and you'll get great support from both of them
Btw, I don't own a hand squeezer. I borrowed one while mine was being repair. The pneumatic squeezer makes your life significantly easier. I didn't realize how good I had it until I had to start squeezing rivets manually. (Thanks again Tom!) Getting all the yokes is expensive, but well worth it in my opinion
Also, it looks like Avery still has this all on sale at the moment. I would move quickly, since I would suspect they'll be posting Sun N Fun specials this week.
bob
