If you have seen the light and have a pneumatic squeezer, bear in mind the pressure that it works at.
I set my air line at two pressures - 85psi for general outlets, I also have a dedicated low pressure outlet set to 45psi with an additional trap filter for spraying.
I have an air receiver around 35 US gallons - 150ltrs. The pump does 14CFM.
However, when you watch what the pressure regulator does between cycles, you may be surprised. If you leave it as stock, the pressure may drop as low as 60lbs before the compressor kicks in. You can adjust it is you wish.
As it falls, the squeezer just won't quite get those rivets as snug as you would like, especially if you are on #4, long rivets.
So, if you are doing bigger rivets, make sure the tank is topped off and the pressure is up![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
