Pmag ignition adapters
brian257
I have a set of 18mm to 14mm auto plug adapters that were in a set of O-200 cylinders that someone gave me and I want to use them on my O-360A1A with a PMAG. They should be the correct length, but to confirm does anyone have a set of the short reach adapters from Emagair sitting around so you can give me a measurement from the end of the threads that go into the cylinder to the shoulder(without the copper gasket installed) and also the overall length. So basically what I am looking for is the length of the threaded section that screws into the cylinder and the overall length of the inside threads so I can figure of if I need to use plugs with the same reach that Emag is recommending.
Threads (without gasket) is .485. Total length is .698.
Mine were manufactured by Robert at EFII, but since they use the same NGK plug they should be dimensionally close enough for a comparison.
