Plastic brake lines fittings & inserts
yankee-flyer
Page 27-04 step 5. The drawings and arrows show 3 90 deg elbows and 1 45 deg one the left master cylinders, but the text says "F-69-F-04X2 (two 90 deg). Looking ahead, other drawings show 3 90 deg elbows so I assume this is another typo that never got fixed?
May have found a better way to do the metal inserts for the plastic lines. Instead of putting the sleeve 1/8" from the end (tried that several times) I moved it down about an inch or so. Heated tubing and insert went in fairly easily. The I set the sleeve between the well padded (rubber, actually) jaws of my vise (just drop it in, don't squeeze!), put a piece of dowel on the end of the tubing and tapped it gently until the end was 1/8" from the sleeve. Anybody see any problem with this as long as the sleeve isn't scratched or deformed?
Wayne 120241
Wayne 120241
I know I reported this problem to Vans when Marty, John, & I found it . Looks like they have not fixed it yet.
I don't think your idea will not cause any problems.
