Just checking to see if anyone has connected the Lightspeed Plasma III timing output to the G3X through the GEA 24 successfully. The output is in .01 volts per degree of timing and I'm wondering if the G3X can calibrate that low a voltage. I know there is a module out there for converting to the 0-5 volt range, but before I go that route I'm interested in knowing other's experiences with a direct connection. Thanks!
