Plans management
JDA_BTR
I'm curious how we all manage our plans. I've had mine on a desk, on a wall, on a TV connected to a PC. The 14 plans were super convenient, the 8 plans a bit unwieldy.
Curious if someone ingenious is doing something I want to copy!!!
I just went with the wall approach. I hung a shelf to put the manual on, then put a board on French cleats above it and clip the plans to it. I rarely move the plans, but depending on what I’m working on, sometimes I’ll grab the board and hang it on cleats on another wall so it’s closer for reference. I always have binder clips on a few different sheets for easy reference so I don’t have to thumb back and forth trying to find a particular drawing. Low tech, but the setup works fine.
wall and book
Also use the wall like Brandon, plus a spiral bound book on the bench that is very useful for flipping back and forth.
An old Mac Mini on a widescreen in front of where I work displaying the PDF's. Sometimes I'll put up the big paper prints in a plastic sleeve, but that's just a general referral, whereas I scroll, zoom, flip between etc on the electronic dwgs.
The best method I have seen to manage paper copies was done at a prior job, where we had classified drawings which had to be kept track of. The drawings were laminated as a roll and setup on a table just like a scroll.
Was easy to roll the drawings 1 way or the other in order to get to the drawing in question. Being laminated you could use markers on it for notes if needed.
horizontal-scroll-or-parchment-with-wooden-handles-isolated-clipping-picture-id1224090236
I settled on using an old music stand... it's nice to be able to float the plans around the shop, but not take up any bench space.
Lance
Plans
I prefer the full size. My plans live on a home brew plans easel. It started attached to the wing cradle but is currently attached to the wall. There is a clear poster acrylic over them to keep them clean. It is also handy for dry erase marking. Huge binder clips hold it all together.
Plans holder
My shop has a standard insulated garage door. I fabbed up a holder frame out of 1x1’s and some 1/4” plywood. It just hangs on 2 hinge pins that go through the door hinges. I can easily take it off to switch the pages. I can also open and close the door with it in place. For quick reference the small set in the ring binder along with a magnifying glass is never far away.
Don Broussard
RV9 Rebuild in Progress
57 Pacer
I had a local blueprint shop make copies 18" high and I keep a set of these on a workbench. Plus I have the PDF in my computer and on the iPad.
I like to sometimes make notes on the paper copies.
Dave
Don, that might be something I copy. My garage door is similar. Are the hooks any special shape and did you screw into the door?
