flion
So the 'Show your panel' thread got me to thinking... What will I have to run aft of the panel? I'm expecting a G900X (or it's equivalent in 4-5 years if I take that long), with the works, including A/P. Possibly Vertical Power, but that should be mostly forward the panel. So, what I foresee is:
Wings - Nav and strobe, pitot heat, landing/taxi lights, NAV antennae, Marker antenna (I'm happy with my Archer antennae so far), trim servo, and roll servo, plus plumbing for AOA or wiring for stall switch.
Fuselage/Tail - COMM antennae, transponder antenna, ELT antenna and remote, pitch servo, magnetometer (does Garmin use a remote magnetometer like BMA?), 4 place intercomm, rear seat entertainment systems\power, heater\ac wiring (I'm pondering the weight\benefit ratio still), overhead eyeball lights, strobe power supply, tail nav light, trim servo, door and baggage door latch indicator wiring, flap motor, and GPS antennae.
Did I miss anything? What other remote sensors for the Garmin might need to go back there (their site is not really informative in this regard)? Based on my experience with the -6A, I'd like to be a little better prepared for wiring runs as I build the structure rather than trying to make them work after the fact.
While I'm at it, any structural considerations forward of the firewall for Garmin's equipment? Where have people been installing those boxes?
