The garage has gotten too cold to warm back up for riveting sessions on weeknights. So when I get home from work, I'm starting to turn my attention to electrical and avionics layouts.
Based on the discussions kicked up by the GTN 625 promo, here's my first stab at an interconnect list for a hypothetic system setup. Does anything stick out as glaringly wrong, should be improved, or otherwise? Most interesting is how, in a GTN 625 thread (http://www.vansairforce.com/community/showthread.php?t=123251), Brian @ Garmin says to connect the GTX 23 to the GDU display directly, rather than through the GTN. I'm a bit out of serial ports on the GDU screen it looks, though.![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Let me know your thoughts. I'll be designing other variations on this list, with a 2nd GDU display (at which point I won't have serial port shortages.
), maybe a GTN 650 replacing the one GTR 20 & VAL NAV 2000, etc. But this is what I consider my base configuration for now.
Thanks!
(Ignore the connector notes - those are for me to start laying connector schematics out in SchemeIt)
1-Screen G3X Touch 460 w/GTN 625, 2x GTR 20 COMs, VAL NAV 2000 NAV
Thanks!
- GDU 460 (9 pin, 50 pin)
- CAN Bus
- RS-232 to GSU (P4601): To GSU 25 RS-232 1
- RS-232 1: To GDL 39R RS-232
- RS-232 2: To VPX Pro RS-232
- RS-232 3: To GTN 625 RS-232 4
- RS-232 4: To VAL NAV 2000 RS-232
- RS-232 5: To GTN 625 RS-232 3
- GSU 25 ADAHRS (9 pin, 15 pin)
- CAN Bus
- RS-485: To GMU 22
- RS-232 1: To GDU 460 P4601 RS-232
- RS-232 2: To GMU 22
- RS-232 3: To GTX 23 ES RS-232 1
- GEA 24 EIS (9 pin, 50 pin, 25 pin, 37 pin)
- CAN Bus
- GMU 22 Magnetometer (??? pin)
- RS-485: To GSU 25
- RS-232: To GSU 25 RS-232 2
- GMC 305 A/P Head (15 pin)
- RS-232 1: ?
- RS-232 2: To GSA 28 Roll Servo RS-232 1
- GSA 28 Roll Servo (15 pin)
- CAN Bus
- RS-232 1: To GMC 305 RS-232 2
- GSA 28 Pitch Servo (15 pin)
- CAN Bus
- GAD 29 ARINC (9 pin, 25 pin)
- CAN Bus
- ARINC Xmit 1: To GTN 625 ARINC In Air Data
- ARINC Xmit 2:
- ARINC Rcv 1: To GTN 625 ARINC GPS
- ARINC Rcv 2: To GTX 23 ES ARINC-429 Out 2 (Hi-Speed)
- ARINC Rcv 3:
- ARINC Rcv 4:
- GTN 625 (78 pin, 26 pin)
- ARINC Out GPS: To GAD 29 ARINC Rcv 1
- ARINC In Air Data: To GAD 29 ARINC Xmit 1
- RS-232 1: To GTX 23 ES RS-232 2
- RS-232 2:
- RS-232 3: To GDU 460 RS-232 5
- RS-232 4: To GDU 460 RS-232 3
- GTR 20 COM 1 (37 pin)
- CAN Bus
- GTR 20 COM 2 (37 pin)
- CAN Bus
- VAL NAV 2000 (37 pin)
- RS-232: To GDU 460 RS-232 4
- GTX 23 ES Transponder / ADSB-Out (60 pin)
- RS-232 1: To GSU 25 RS-232 3
- RS-232 2: To GTN 625 RS-232 1
- ARINC-429 Out 1 (Lo-Speed):
- ARINC-429 Out 2 (Hi-Speed): To GAD ARINC Rcv 2
- GDL 39R ADSB-In (9 pin)
- RS-232: To GDU 460 RS-232 1
- Vertical Power VPX Pro:
- RS-232: To GDU 460 RS-232 2
