Recently there have been a few threads on VAF about planning the panel. Here is my last iteration.
The idea is to have a VFR cross-country panel.
As I'm flying in Europe, the rules are not the same as on the other side of the Atlantic, for the time being day VFR only.
My idea is to have at least one EFIS but be able to fly with the EFIS inop, that means I need some engine monitoring capability outside the EFIS. I choose a GRT system, the EIS 4000 being rugged and proven.
The EIS 4000 would be a single point of failure and would ground the plane but it seems to me it's easier to replace (smaller, less expensive) than having to wait for an EFIS to be delivered over here.
I'm still pondering the type of EFIS : Sport or Horizon. The only problem I have with the Sport is the lack of analog inputs for trim and flaps.
Here is a picture of a single EFIS layout :
All one time a flight switches are on the left, some switches are missing as is the parking brake handle.
Switches used a bit more are near the throttle.
Autopilot switches are located near the autopilot and EFIS.
Annunciator lights functions are still open to debate (EIS, Low oil, Fuel pump, E-bus......)
As I would like the plane to be flyable from both seats, I might go to a dual display panel (finances allowing). This will be possible by moving a few items but the general idea would remain the same.
