I have been flying my -10 for over a year but have noticed a progressive problem with the alternator field. Increasingly, the annunciator light from the PlanePower alternator illuminates on take-off and in cruise, meaning that charging of the battery has stopped. I have an EXP Bus II switch and solid state breaker panel and I have bypassed its overvoltage detection (jumper) since the alternator already has protection built-in and I wished to isolate the problem. I can get 5-30 minutes of charging again after cycling the alternator field switch, but it is a constant hassle to reset while in flight.
I've shed all possible load to determine if there was some excess draw on the charging circuit, but can find no offending item. Charging shows as around 13.3V when the charging circuit is active, which is normal, but drops below 12V eventually when field drops, which is also normal, but it shouldn't be dropping.
PlanePower tells me that the sensing circuits are thermal, detecting overvoltage by excess heat on the wire. Given that I have bypassed the switch panel's detection, my current diagnosis is that the sensing device at the alternator is experiencing too much heat - possibly from the engine exhaust radiant heat and not from the line load, rather than from load. Or, it is possible that the sensor is defective.
Have any of you -10 operators with the standard PlanePower alternator also experiencing charging field loss like this? If not, does it make sense that the alternator might need some heat-shielding? Or, is it probable that the alternator is simply defective in its OV-field processing?
