CharlieWaffles
I'm checking to see if I am in a unique situation. I have the awesome Door Gas Strut Brackets from PlaneAround and have also bought some upgraded (heavy lift) gas struts from BAnsbach Easylift that a few others have reported to using (700 newton struts).
Is anyone else using this combination? I am finding the eyelets on these struts are too thick to fit between the ears of the PlaneAround bracket. They do work with the stock brackets, but Sean has designed his bracket with thicker ears so you dont need as large of a bushing as the stock set up.
