Toobuilder
The -8 I've been flying has the standard Vans pitot tube setup (AN bulkhead fitting and bent -4 tube). I'm upgrading to a heated pitot tube and mast and happened to note with horror that the current tube's bulkhead fitting is mounted in a hole drilled right through the lower spar cap.
Someone please tell me this is per the blueprints!![Eek! :eek: :eek:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
