Shouldn't Have To Open The Skin
I installed a heated pitot after the plane was built. There is a doubler plate in the Gretz kit that has a "joggle" on the front end to allow it to fit over the spar flange. I drilled out the rivets (4, I think) in that location, fitted the doubler inside the wing, and marked the drill locations thru the holes. IIRC, I also attached an angle to the doubler to allow attachment to the wing rib. Lots of fitting and checking before riveting with Cherry Max. Pitot is very rigid with this setup. On the other hand, my brother attached a heated pitot to the skin only on his RV6 and just used a doubler- no attachment to the rib or flange. So far, it seems to be OK.
Terry, CFI
RV9A N323TP
