I think this discussion is slightly academic. True, for VFR flight no checks are needed as long as you don't have a transponder. But for much of the US this is impractical. Especially in an RV-10, you'd be limited to below 10000' without a mode C transponder, no Class C, 30 miles away from class B, etc.. And if you have a mode C then they check for "data correspondence", eg it's sending out the right altitude. And since (most?) of us get the mode C altitude from an EFIS, you end up doing a static check on it anyway, even if indirectly.
In the US part 91 requires these checks for IFR operations.
I looked into the possibility of buying the required test equipment to do the tests myself (as the manufacturer), and perhaps sharing the costs with others. Turns out the FAA requires frequent (I think every 6 months) and expensive test lab re-calibration of the equipment, so you need to get a lot of use out of it to amortize that cost. Our local 'pro' has 2 test sets, at any given time one of them is in for re-calibration. This is his full time job, btw.
