How are you routing the pitot and AOA tube from the wing root to your aft fuselage located ADHAR? I am looking at routing up by the vertical frame at the main spar box and then aft under to arm rest. Anyone else tried that route?
I put conduit under the baggage flooring and then brought it up the center support for the baggage bulkhead. The conduit is plenty big enough for the 2 tubing runs.
Thanks Bruce. After looking at it again today I decided to pull the baggage floor and route the pitot and AOA lines underneat it along with my left strobe cable.
